I want to accept two objects and copy them.
but only one object is copied.
What’s the problem?
Thanks in advance.
What’s the problem?
Thanks in advance.
Your “spacing” text panel has a value of “0” for the X vector so one of them doesn’t move.
definitely check the panel for any whitespace characters like what joseph says since that got me when i first started using panels. also you may need to graft either the G or T
There is no white space in that text panel. The value of zero for an X vector is useless.
thank you.
i have one more question.
I want to use 1 list and copy 2 objects at spacings in the list.
