Copy paste from Autocad LT
A colleague and I discovered a difference in copy pasting from Autocad to Rhino8 and from AutocadLT (lite version) to Rhino8. We use the same rhino version but he is working with a normal Autocad and I’m using the LT version. If I paste something from Autocad I get the option to paste a image, while my colleague pastes the lines itself. Is there a fundemental difference between the two applications for it to not work with AutocadLT?
Rhino 8 SR13 2024-11-12 (Rhino 8, 8.13.24317.13001, Git hash:master @ ca3666c3ebed2b9567e10930077bfa0884f65db9)
License type: Commercial, build 2024-11-12
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Computer platform: LAPTOP - Plugged in [85% battery remaining]
Primary display and OpenGL: NVIDIA RTX A2000 8GB Laptop GPU (NVidia) Memory: 8GB, Driver date: 7-23-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.86
- Windows Main Display attached to adapter port 1
Primary OpenGL: NVIDIA RTX A2000 8GB Laptop GPU (NVidia) Memory: 8GB, Driver date: 7-23-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.86
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 128MB, Driver date: 4-2-2024 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-23-2024
Driver Version: 31.0.15.5286
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino8.Plugin.dll “Enscape.Rhino8.Plugin” 4.2.0.1589
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.13.24317.13001
My guess it that since Autocad LT has limited functionality (no addons for example) it isn’t capable of reading the clipboard info.
But shouldn’t rhino be reading the clipboard?
Have you tried different object types, like plain text, or geometry? Rhino has pretty advanced clipboard reading capability, guessing its on the Autocad LT side.
We are running Autocad lt and get the same functionality in both directions. Instead of geometry getting pasted, we get images like screenshots of the viewport.
When I check the %Temp% file where Windows stores clipboard contents there is a .DWG file with the contents in it. If I drag and drop that .DWG file into Rhino and select Import, it imports just as expected. It seems like the issue is with how Rhino is processing the clipboard contents. I can’t find any reference to a setting for this, but it seems like it should be achievable.
Hi Ryan,
What version of Rhino are you using?
I just did a quick test of Copying a Curve from Autocad to Rhino 8 with no issues. Going from Rhino to Autocad is a bitmap.
Any help would be appreciated. I didn’t even know this was supposed to work until today. I was thinking about trying to create a tool to achieve it and learned it is already supposed to function that way.
Here is the System Info:
Rhino 8 SR23 2025-9-8 (Rhino 8, 8.23.25251.13001, Git hash:master @ e75a9d62e23cc6f52d4ef68eb7eda9f8da9b6cd9)
License type: Commercial, build 2025-09-08
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 8.0.21
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3060 Ti (NVidia) Memory: 8GB, Driver date: 6-12-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 576.80
- Secondary monitor attached to adapter port #2
- Secondary monitor attached to adapter port #3
Intel(R) UHD Graphics 770 (Intel) Memory: 2GB, Driver date: 9-19-2025 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 6-12-2025
Driver Version: 32.0.15.7680
C:\\Program Files\\Rhino 8\\Plug-ins\\SolidTools.rhp	“SolidTools”
C:\\Program Files\\Rhino 8\\Plug-ins\\Commands.rhp	“Commands”	8.23.25251.13001
C:\\Program Files\\Rhino 8\\Plug-ins\\WebBrowser.rhp	“WebBrowser”
C:\\Program Files\\Rhino 8\\Plug-ins\\rdk.rhp	“Renderer Development Kit”
C:\\Program Files\\Rhino 8\\Plug-ins\\RhinoScript.rhp	“RhinoScript”
C:\\Program Files\\Rhino 8\\Plug-ins\\AnimationTools.rhp	“AnimationTools”
C:\\Program Files\\Rhino 8\\Plug-ins\\IdleProcessor.rhp	“IdleProcessor”
C:\\Program Files\\Rhino 8\\Plug-ins\\RhinoRenderCycles.rhp	“Rhino Render”	8.23.25251.13001
C:\\Program Files\\Rhino 8\\Plug-ins\\RhinoRender.rhp	“Legacy Rhino Render”
C:\\Program Files\\Rhino 8\\Plug-ins\\rdk_etoui.rhp	“RDK_EtoUI”	8.23.25251.13001
C:\\Program Files\\Rhino 8\\Plug-ins\\import_ACAD.rhp	“AutoCAD file import: import_ACAD”
C:\\Program Files\\Rhino 8\\Plug-ins\\NamedSnapshots.rhp	“Snapshots”
C:\\Program Files\\Rhino 8\\Plug-ins\\MeshCommands.rhp	“MeshCommands”	8.23.25251.13001
C:\\Program Files\\Rhino 8\\Plug-ins\\RhinoCycles.rhp	“RhinoCycles”	8.23.25251.13001
C:\\Program Files\\Rhino 8\\Plug-ins\\RhinoCode\\RhinoCodePlugin.rhp	“RhinoCodePlugin”	8.23.25251.13001
C:\\Program Files\\Rhino 8\\Plug-ins\\Toolbars\\Toolbars.rhp	“Toolbars”	8.23.25251.13001
C:\\Program Files\\Rhino 8\\Plug-ins\\3dxrhino.rhp	“3Dconnexion 3D Mouse”
C:\\Program Files\\Rhino 8\\Plug-ins\\Displacement.rhp	“Displacement”
C:\\Program Files\\Rhino 8\\Plug-ins\\SectionTools.rhp	“SectionTools”
@RHammer - knowing the version of AutoCAD LT you have might be helpful.
– Dale
Here is the AutoCAD version as well as the .DWG file taken directly from the %Temp% folder.
A$Cd11b9d02.DWG (128.9 KB)
Thanks @RHammer - I’ve logged the issue so we can take a run at this.
– Dale
Now that we have copy paste functionality from AutoCAD lt to Rhino, is there any easy route of getting it to work in the other direction? Would adding the clipboard format to the Rhino export be enough? Or is it far more complicated than that? I played around a little with the temp files and can’t readily tell how AutoCAD is tracking its clipboard contents. It seems to be using the temp file along with some internal tracking, but I really don’t know.
I have a single click macro setup to export overwriting a specific .dwg file currently, then I copy and paste from it to the working drawing, but it seems so close that it should be within reach.
I’ll include a snip of the clipboard contents from each program in case it is helpful and am happy to put some work in towards gaining this functionality if anyone can offer a little guidance in how it should be approached.
