Copy of Technical Display Mode and Clipping Planes
G’day everyone,
I have a copy of the Technical display mode and it isn’t showing clipping plane intersections. Any hints where the settings are for this in the copies display settings?
Technical Display
regards,
Nick.
I can’t find those either but - FWIW - my copies of the technical display all clip the geometry at the clipping plane intersection.
Hi Nick - this should be in the Display panel when the mode is active… Clipping plane settings > Show Fills, Show Edges… do you see that?
Yup. Thanks!
But … is it by design that these settings are not exposed in the view options?
Hmmm… I don’t see it yet!
http://mcneel.myjetbrains.com/youtrack/issue/RH-33619
thanks,
Thank you @pascal, that sorts it out.
Thank you @wim, for confirming I’m not mad.
