Copy Detail from Viewport
I remember on Rhino 7, there was a command that was able to copy of the curves visible in a certain detail view & extract it from model space to the layout space. I distinctly remember this because, I am trying to standardize my detail sheets & this was really useful. The copy “copy detail” & “copy viewport” commands are not geared for this. Something like a flatten command or an extract command. Anything helps. Maybe it’s a different command altogether, I don’t remember.
ChangeSpace?
Yes, I completely, forgot about this command, this is it. Thank you.
iT’s not change space, it’s another command altogether, Ill find it and post it here.
Are you thinking of Make2D?
No, it’s a command that drags your highlighted item in model space and copies it into layout & a converse command that copies what in the layout directly into the model space & you can toggle the viewport crop as well. I always forget the verbiage associated with it.
Never mind, it’s the change space command, my bad, thanks for the help.
