I am trying to do this shape on SubD.
Can someone help me with this ?I tried SUBD but I am going very well with that one.
Thank you in advance.
Attached is an example that shows the basic structure. I leave it up to you to refine. (Uses Radiate for radial symmetry)
sculpture_structure.3dm (221.3 KB)
What is Sharp?
Hi Mitch -
That’s the command to create less-soft edges on SubD objects - a.k.a. soft creases.
Thank you so much Gijs. I see how you’ve achieved the structure. You’ve also used “reflect” or mirror the top with the bottom.
Thanks again
