I’m trying to extract the boundary from a room from a linked in Revit model and use this boundary to define a shaft opening for an existing slab in my model.
There are many levels with different rooms at each level. So the boundary would need to know at which level it is and then only create the opening for the floor which is at the same level.
You will want your Rhino Document Units to Match the Revit Document.
You can set the default when opening Rhino, this setting will let you set a different Default for Rhino.Inside.Revit vs just opening Rhino, since revit often works in Feet or Meters where people prefer to work in inches /mm in Rhino.
