I imported a 3d building model online in DWG and opened it on Rhino. The volumes are in mesh with multiple triangle. How do I convert it to volumes made up of single planar surface on each surfaces. Images attached are the mesh volumes and the planar surface volumes I would like it to become.
I have tried reduce mesh, meshtonurbs etc, but there are still multiple unnecessary triangles.
Its only visual, as meshes inside of rhino conceptually can only be made up of triangles and quads, if you sub-object select an ngon face you will see the underlying faces again.
