Convert Brep to NurbsSurface
I am trying to convert the patch output (brep by default) to a Surface so I can use the Surface.ShortPath method within the same component. Currently the only way I can convert is to input it into a different component as “Surface” datatype. Is there anyway to convert this internally within one compenent?
Thank you in advance!
PatchSurface.gh (13.4 KB)
Hi @shahe,
to get it as trimmed brep face you could use:
B = patch.Faces[0];
to get the underlying, untrimmed surface you could use:
B = patch.Faces[0].UnderlyingSurface();
does this help ?
_
c.
Hi @clement ,
Thank you very much! Yes, that’s exactly what I needed. I ended up doing the following to convert the trimmed surface:
Surface patchSurface = (Surface) patch.Faces[0];
Thanks again for the help!
