Conversion problem from AutoCad --> Rhino
On daily basis I have problems with opening an AutoCad drawing with solids in Rhino (7 or 8 doens’t make a difference) Am adding the screenshots and files themselves. Has anyone had a comparable problem?
AutoCad Solid .dwg
After opening the AutoCad .dwg in Rhino:
AutoCad - Rhino Conversion.dwg (129.6 KB)
AutoCad - Rhino Conversion.3dm (405.2 KB)
Hi Jan-Marten,
Thank you for sharing your problem. In our videocall and with your file I was able to understand what the problem is, but I also have no solution.
So I it would be nice when we can have some clarification from other people or McNeel experts.
It makes me curious.
hi @j_m_rottine1 I’ve logged a bug for this so that we can investigate
RH-97921 Import issues with DWG
The issue has been fixed, let me know if you need the (bleeding edge) build of the day (Rhino 8.36 dujour) to start using this already, I can send that in a PM
AutoCad - Rhino Conversion.3dm (420.7 KB)
That’s really fast!
Hi Gijs,
We have been experiencing exactly the same problems in our company for years as Jan-Marten posted here. This also happens when importing some exported Inventor DWG files with complex radii.
Very fast response!
Will this fix be included in the next Rhino 8 update?
What was exactly the issue?
Hi Lambertus -
The fix was made in 8.36. The current stable release of Rhino is 8.34, with weekly public releases of the 8.35 release candidate. On September 8th, 8.35 will become the stable release and the first public version of 8.36 will be made available as a servicer release candidate.
A hardcoded trim curve tolerance of 0.001. The trim curves in the example that was posted were less precise than this hardcoded value.
Is it the ‘Angle tolerance’ accuracy?
That was my first idea of the problem, but I was not able to have any influence on that.
ps. I was wrong as I now read that it was a ‘trim curve tolerance’ setting.
Yes, Please. I like to try 8.36 even knowing that it can be unstable.
Thanks everyone and Wim Dekeyser. I installed 8.36 Tested with 2 files which gave problems and now the result is perfect. This is a very good start of the weekend.:+1:
@wim , @Gijs is this fix going to make it into the next R9 Beta?
yes, fixes that go into 8.x automatically go into 9.x as well
Oke. Now I faced a problem in 8.36 with a U-profile. Created in Shipconstructor. exported to AutoCad. Result is oke, no problem. When opening this AutoCad in Rhino 8.36 it says Invalid polysurfaces and the result is not oke. Attached screenshots and both Rhino and AutoCad file. In the Rhino file, I copied the U profile aft and changed it myself as it should be.
U60x30x5.3dm (449.9 KB)
U60x30x5.dwg (9.5 MB)
thanks @j_m_rottine1
Logged as RH-97995 DWG import: bad object
Hi @Gijs, I have tested this version on a part of a DWG where I had this import issue.
I have still the issue.
Can you have a look with this drawing?
BS-U02_26.03.2025_Export_Stripped.dwg (12.4 MB)
thanks @Lambertus_Oostervee1 for the sample,
I’ve reopened the issue.
FYI the file can be opened correctly if you increase the absolute tolerance from 0.001 to 0.01. Even 0.002 works successfully.
@Gijs The Absolute tolerance setting in Units is now:
on the Model tab 0.01
on the Layout tab 0.001
Do I need to change the setting on the Layout tab?
Is this different from the solution in version 8.36, or are they related?
It’s not as advise to change the document tolerance, but rather a workaround. Rhino should import this correctly without this, and currently it doesn’t.
Just model absolute tolerance. Layout doesn’t matter.
RH-97921 is fixed in Rhino 8 Service Release 36
