Control sine wave area
I follow some sine waves tutorial to create deformation on surfaces and I wonder if there is a way to avoid the deformation of the surface edges ? So the rectangle can stay a perfect rectangle on the edges and be deformated only on the center.
Thank you in advance !
You need to make sure ‘edge’ points aren’t being affected - though different project, there’s an example here:
Share your file if you want more help.
Best
Sine wave on a surface.3dm (480.2 KB)
Sine wave on a surface.gh (10.1 KB)
