Hi Daniel, does the CullControlPolygon command do it when turned OFF ? Why not use a transparent shaded material in a dedicated display mode with individual Control Polygon settings, eg. solid lines in different color etc. ?
thanks for your suggestion, but CullControlPolygon is off for that screenshot.
When using a transparent shader, you see ALL other objects behind the surface.very distracting.
I just want to clearly see all the control polygons/points on the object I am currently editing. also transparent shading takes away surface detail (shading), that is important as visual feedback during surface modelling.
I´ve feared that. Another, rather ugly workaround would be:
Use ExtractControlPolygon of your surface
select the resulting mesh, run _ExtractWireframe
group the resulting lines
delete the mesh
Select the grouped lines and run _BringToFront
Group the lines with your surface
Select the result and turn _PointsOn
This way you have a control polygon which is in front regardless of the shademode or transparency. The downside is, you can only window select controlpoints and the gumball will not allign to object anymore.
I guess it would be possible to write a python script which sets up a display conduit which permanently draws a control polygon in the foreground…
+1 for a display mode setting which allows to draw the control polygon of curves and surfaces in front of everything.
Ha! that is a nasty hack indeed, for points to be visible, one would need to run extractPt, too.
anyways, thanks for the input!
I really hope this can be added, it used to work like that… long time ago.
I do see an advantage in being able to tell where the ControlPolygon intersects the rendermesh mesh, (the CP line disappearing), but I’d prefer an option to render maybe a differently coloured ControPolygon if behind the surface, or just an intersection point looking different from the CP.
i got u ! but if they are not point objects, bringToFront has no effect.it works on lines but not the lines controlPoints. at least that is what i see here.
