Control point curve won't bend?
Hello
I have no idea why, but my control point curve tool won’t curve between 3 or more points? This is really frustrating as this is one of the tools I use the most. Did I accidentally turn something on/off og is this an error in the program?
My curves just turns out like this?
Check the degree in the command line of the _Curve command - it’s probably set to degree 1. Set it back to 3 (default) if that is the case.
Thank U!!! that did the job! Perfect thanks!
This PDF includes really good information on the effect of the Degree of the curve:
