Hi guys, today I’ve the following problem.
I should create a kind of infill inside a closed curve. The algorithm I created perfectly works for convex curves, but when I tried some concave curves something went wrong. How can I fix it?
Hello
I am not sure it is so simple. I have done many infill strategies. But I searched making a closed curve. Here you have an opened curve. It must work if the infill is rotated. If not you will have some problems. Try to draw what you want, and you will see the problems or the strategies to take it into account.
By hand. It illustrates the difficulty of writing code to solve this. If three separate curves are OK, some kind of loop might get there but… definitely not simple!
