is there a way to create this hatching (blue) in Grasshopper? However, the hatching should be output as a line, which should have 1mm distance to the red lines and 2mm distance to each other.
The whole thing is to be used as a path for a 3D printer, which unfortunately cannot be operated with a normal slicer.
Hi thanks again for the help, your plugin has worked really well so far. I work at the university with a clay 3D printer. In the last correction I was told that I should use the offset infill instead of the lines infill. However, the offset infill doesn’t really work for me. Do you have any ideas as to why this might be and how to fix it?
Offset Infill.gh (12.6 KB) Offset Infill.3dm (217.7 KB)
This is the first time I’ve worked with Grasshopper at university, so I’m not particularly experienced.
So I apologize for any stupid questions.
Hello
yes it doesn’t work on purpose. There must be a warning on components ? Components with a yellow square needs a licence. Go on food4rhino nautilus and look at the instruction. I could send you an evaluation licence for 15 days.
here the results, better looking with slight decrease of tolerance (don’t go too low it is too slow)
