I am trying to connect a series of points together with a line in the Z direction. The complexity starts when these points connect to each other with diagonal lines that are not good for my purpose. (It supposed to be a distributed columns in a plane where it also has to serve the function of holding the above floor weight).
Back to the points, I draw a sketch of how they should be connected. Basically, they are connected either to the top points or the near points where I call the “X” “Y” and “D” (any other suggestion are welcome).
I attached the main file where I got help here and the sketch so that’s easier to understand.
Thanks
