I pulled the vba script below from another posts. I’m new to Rhinoscript and can not determine why Rhino opens but then terminates when the script ends. (@ the End Sub). I also had to add a visible true command in there to see rhino but it terminates at the end of the sub. Here is the code:
' Main subroutine
Sub Main()
Dim RhinoApp As Object
Dim Rhino As Object ' e.g. RhinoScript
Dim strFile As Variant
Set RhinoApp = ConnectToRunningRhino()
If (RhinoApp Is Nothing) Then
MsgBox "Failed to get Rhino interface object"
Exit Sub
End If
Set Rhino = RhinoApp.GetScriptObject()
If (Rhino Is Nothing) Then
MsgBox "Failed to get RhinoScript object"
Exit Sub
End If
strFile = Rhino.OpenFileName("Open", "RhinoApp 3D Models (*.3dm)|*.3dm|")
If Not IsNull(strFile) Then
Rhino.PrintEx strFile
End If
End Sub
' Helper function
Function ConnectToRunningRhino()
On Error Resume Next
Set RhinoApp = CreateObject("Rhino5x64.Interface")
If (Err.Number <> 0) Then
'MsgBox "Unable to create Rhino5x64.Interface object"
Exit Function
End If
Set ConnectToRunningRhino = RhinoApp
End Function
However, since RhinoApp is a local variable to the Main subroutine, when the subroutine ends, the local variable goes out of scope and, thus, Rhino terminates.
I found that if I declared it at the macro level I could make if visible and run “_Open” command to get the strFile to open. It would stay open until I released the Rhino Object.
This Helper Function was posted and works to open Rhino 5. I have two versions of Rhino on my laptop: 5 and 6. How do I get this to work for 6?
Eric
’ Helper function
Dim Rhino As Object
Set Rhino = CreateObject(“Rhino5x64.Interface”)
'MsgBox “Unable to create Rhino5x64.Interface object”
Exit Function
End If
I should mention that I am trying to do this from Microsoft Excel through VBA. The code for Rhino 5 posted above works. I cannot get it to work for Rhino 6. I am setting up a reference to the Rhino.tlb library but it fails to open the software.
I’ve gotten the code below to open Rhino6 from Excel VBA but only if I declare Rhino as an Object. When I set a reference to the Rhinoceros Type Library (C:\Program Files\Rhino 6\System\Rhino.tlb) the code no longer works. This code works for Rhino 5 but not Rhino 6. I’ve tried Rhino.Application and Rhino.Application.6.
Thanks in advance for all the help.
Eric
’ Main subroutine
Private Sub main()
'Dim RhinoApp As Object
Dim RhinoApp As RhinoApplication
Dim Rhino As Object ’ e.g. RhinoScript
MsgBox “Failed to get Rhino interface object”
Exit Sub
End If
MsgBox “Failed to get RhinoScript object”
Exit Sub
End If
strFile = Rhino.OpenFileName(“Open”, “RhinoApp 3D Models (.3dm)|.3dm|”)
RhinoApp.Visible = True
End If
End Sub
’ Helper function
Private Function ConnectToRunningRhino()
Set RhinoApp = CreateObject(“Rhino.Application”)
Exit Function
End If
No, I cannot get the Rhino6 object unless I declare it as and object. I cannot use intellisence when declaring it as an object. I set a reference for the Rhino 6 tlb file but get an error when running the code.
Yes you are correct and I’ve already determined that late binding will work and it is currently what I am using. I do not get access to intellisense this way and although it isn’t a deal breaker it is not ideal. Rhino 5 I can early bind no problem, Rhino 6 I cannot.
I’ll continue using it this way until someone offers up a solution. Thanks for the help.
I finally got to try this out and I constructed the code below and when I run it, it runs with no problem but nothing happens. Appreciate your thoughts:
from ctypes import *
