After creating a Rhino Object like:
Try
Dim rhinoType As Type = Type.GetTypeFromProgID(rhino5x64)
rhino5x64Int = Activator.CreateInstance(rhinoType)
Catch
End Try
If (rhino5x64Int Is Nothing) Then
Exit Sub
End If
Const bailTime As Integer = 15 * 1000
Dim waitTime As Integer = 0
While (0 = rhino5x64Int.IsInitialized())
Thread.Sleep(100)
waitTime += 100
If (waitTime > bailTime) Then
MsgBox("Rhino initialization failed")
Exit Sub
End If
End While
Make it visible and close it with the close button the process stays open in the windows task manager.
When I make it visible again it will have a black ViewPort and I can not open a file.
How can I open a new file when it has been closed?
