Hello. Is there a functionality similar to “Stitch” command that connects two SubD edges at their (variable) intersection? Expected behavior should be similar to “Connect Srf” or “Blend Srf”. Any hint appreciated.
Two mode notes:
“Stitch” sometimes buggy - doesn’t always offer “First”/“Second” option, also there’s no option to select the base point. Zooming and rotating when Stitching is super laggy.
I solved this issue by using Grasshopper to manipuate control polygon edges and rebuildig SubD by that. But it’s rather complicated than easy and works just for certain cases.
Hi Petr - how would you get ‘expect that’ automatically - some edges have to retreat and some extend to get there - it is neither Average, nor First, nor Second…? I do see that it would be handy to see a preview of First/Second/Average and Press enter to accept though.
First and Second are both at the picture attached. I didn’t get the logic of that command - it sometimes offers just “Avegare” option and sometimes just “First/Second” but no “Average”.
By “expect that” I mean that I expect that result from any command or approach…probably different from what “stitch” does.
