Hello, I’d want to connect these lines as seen in the image but i’m so struggling
maybe you could help me…
Because this example is simplified, the solution should apply to any quantity.
Thank you!
Rand
curve tryout.gh (1.9 KB)
Thank you!
Rand
7. This is not a do-my-work-for-me group
Many of us like to help, but it’s good to see effort on our part being matched by effort on your part. Questions in the form of “ I need to do X but cannot be bothered to try and learn the software ” will (and should) go unanswered.
i have played around with pattern and vetor shifts but just can’t come up with a solution
curve tryout2.gh (13.5 KB)
You were going kind of in the right direction. Have a look at this and see if you have any questions:
You original curves are not in the correct order according to your initial request though, which is why the curve is not entirely like the output you want. So you’d need to figure out a way to sort your curves so your input matches what’s on your image.
Edit:
forgot to upload
curve tryout3.gh (8.6 KB)
Try using Pufferfish Move To Point component.
It worked!!
Thank you very much
