I recently started using the SubstanceImporter Adobe plugin to use Substance materials in Rhino. Whenever I use an .sbsar material in a model, I get this warning when I try to save the file with SaveSmall:
I don’t understand this question - when I add the Substance material, I uncheck the “Embed SBSAR file” option in the Material panel, and the material that triggered this message is only 7 MB in size.
I’m not trying to embed anything in the Rhino file (it’s only 2.3 MB), so this and the material size together is still far smaller than the 96 MB in the message.
What triggers this message? Is there a way to avoid it? And if I check the “In the future do not show…” checkbox, will it default to No (as I’d prefer)?
As a suggestion, it may be better to rephrase the message because I don’t understand the source of it and the Yes / No choices aren’t terribly clear either, with respect to the checkbox. (The message is clearly related to Substance materials somehow, because it doesn’t show up in models where I don’t use any.)
