I want to use Karamba3D to calculate concrete forms (3d printed) and for that I need to differentiate between compression and tension, because concrete has very different material properties in those two situations (it is not reinforced). Is there a way to apply different material properties to the different directions?
I haven´t checked if it worksl, but in Karamba3D 2.0.0 (Work In Progress) you can specify the tensile and compressive strength in ft and fc inputs, respectively, for the MatProps component.
