Karamba results
Hi @matttam @cp1
Is there a way in Karamba 3D to get the results of the Max Tension and Compression Stress (Mpa) values of beam structures?
Best
Hi Alim, you can use the Beam Forces component to do this:
More info can be found here: 3.7.10: Beam Forces | English 英文 | Karamba3D 2.2.0
Thanks for that.
I wonder which one is compression value and which one is tension. Can you explain, please?
if you hover over the outputs, there is an explanation - negative is compression and positive is tension
