For the life of me I cannot find any alternate installs.
Can someone explain how this actually works?
Because File > Special Folders > Components takes me here:
to a different place than for example, the path in the below screenshot.
That path is a search of the whole system for the human.gha, which does not return the human.gha located in the special folders path.
The first one would have been installed manually by copying the gha file to the Libraries folder. This is the default location from which Grasshopper plug-ins are loaded. The second was installed by the package manager, most likely when a file was opened that contained components from Human – if Human wasn’t installed at the time then Grasshopper would have given you the option to “Download and Install” it.
You can remove either, but my preference would be to remove the one in the Libraries folder. Whilst the dates are different, the version numbers are the same.
deleted the one in the easily accessible components folder and that solved it.
got similar but different problems with another couple components but got them fixed too.
thanks everyone!
