So a few times when updating our Grasshopper components/plugins folder to have the same across all machines, I sometimes get a component ID conflict plugin warning like this:
So the first thing you notice very quickly here is that the file path only shows the last few levels and ommits the most important part. It is also not linked so you are forced to search for the location of those files.
That clipper plugin, which exists as a Rhino plugin and a grasshopper plugin is especially annoying. When you install the Rhino plugin it also adds a .gha file for the ClipperComponents. But it doesn’t put it in the normal components folder but actually in C:\Program Files\Common Files\McNeel… and not even in C:\Program Files\Rhino 6\Plugins… So that’s already a location I didnt even know exists.
So now back to the ID conflict warning. I am not even sure what Replace All and Skip All is supposed to do, because both basically do nothing as far as I can tell. On next startup you still get the same warning. It even says “You will not be asked again for this component library”. Sure enough on next startup you are presented again with the same warning regardless of what button you pressed.
So what are Replace All and Skip All SUPPOSED to do? There is no explanation given of what they will do and the names are not explanatory either.
Wouldn’t it be cool if the paths would be linked (how they are for Rhino plugins when you go to details) so you can go to either components file location.
The other question is of course why are there so many different possible locations in the first place? There is the Grasshopper components folder, Rhino Plugins that have GH components, Rhino Common Plugins that have GH components and the YAK package manager. All of those locations are hidden like 10 levels deep in obscure locations. Adding to that they are all locations which are not indexed by windows so you can’t even search for them (at least nothing came up when I searched for either of the Clipper .gha files).
Lets not even get started on food4rhino…
All in all it is always a pretty frustrating experience when it comes to GH plugins.
