Hello there, I’m trying to get a shape like this:
I’ve tried mutliple approaches, BlendSrf, NetworkSrf, Sweep2, but none are giving a clean smooth-flowing seamless result, Does any of you have any idea’s?
Thanks,
Peter
Hi peter,
Could you upload a sample file?
Here is a file with the object in question
ExampleFile.3dm (1.4 MB)
A lot of seemingly complex corners turn into simple fillets(you can substitute blends) when you think about the intersections of larger shapes, and I suspect your typical everything-plus-the-kitchen-sink MCAD suite can make that fillet with little problem. I tried it with Rhino and it trims off the fillet okay but it doesn’t extend the lower surface up to fill in the gap.
ExampleFile_2.3dm (488.2 KB)
Thank you very much for all the advice, and in special @vittorio for the clear step-wise explanation the information you guys are providing gives me some good inspiration on how to get this shape even closer to the real object then I was able to get it up to now.
“here is a way” Could you elaborate on how you did it?
