Trying to NetworkSrf those curves. They perfectly meet in the center and tolerance was put much higher to avoid any misalignment. Still it only works with border curves and sometimes one curve inside.
Do you know any other way to create nurbs surfaces with such specific positions and directions than NetworkSrf? Anything lower level?
Hello - without the curves it is impossible to help but if those curves all cross in the middle I can see how that might not work. But… why? What are you after, here? Does it need to be a single surface?
Thanks for the reply. 3dm with Curves attached, script as well if you’d like to take a look.
I tested basic example of ‘flipped’ NetworkSrf and it worked. This obviously is a whole new level, but I am wondering if there is a ‘lower level’ way to define nurbs surfaces.
The reason is making cuts in surfaces. Cuts not along direction of isocurves become many times heavier and impossible to work with in other programs like revit.
