Hi guys,
I have been posting a lot lately, it seems I have stumbled across some data management challenges that I have never faced before… plus some last minute changes…
The operation I need to run is rather simple, but things get complex on the data I need to run it.
Basically I am trying to generate a connection from closed curves to another. This version just draws a line from mid point (blue) and joins the nearest with Proximity (white)
The structure, you could say, is 2 trees: First one with 3 rings, second one with 4 rings.
Things get complex when I have multiple rings in 3D.
I believe the structure I need is the same as with the simplified example: Have each contour level be a tree, which is then divided in rings.
But I cant seem to achieve this structure once I run contour…
DataTreeConnections.gh (71.5 KB)
Any help is much appreciated
Shynn
