Como puedo realizar este ejercicio en grasshopper?
Two identical topics…
Delete one?
@Angel_David_Olguin_O
You could get the centroids of the objects with mss properties, then use a scale component that you feed with a range component that is fed with a list length, that is fed with the list of objects you want to scale. This assumes your objects are in an ordered list.
te funciona esto???
cubes.gh (10.0 KB)
