Command Set Duplication - Gray
Hi there,
I like to create a custom Command Set for me, but die Duplication Button is grayed out.
In Detail:
The default Command Set is read only und normaly I should be able to duplicate it and edit the New one. But all Buttons in den Command Set selection Dropdown are grayed-out.
How it should work:
http://docs.mcneel.com/rhino/mac/help/en-us/index.htm#macpreferencesandsettings/commands.htm
How it looks:
Software information
Software versions
Rhinoceros version: 5.1 (5B161)
IronPython version: 5.1.2015.131
Language: en
OS X version: Version 10.11 (Build 15A284)
Plug-ins
/Users/Wolf/Library/ColorPickers/SkalaColor.colorPicker/Contents/MacOS/SkalaColor
Third party kernel extensions
at.obdev.nke.LittleSnitch (4352) 21E0BDAF-EA9E-31B1-885D-E56F37C9EB7A
com.silabs.driver.CP210xVCPDriver64 (3.0.0d1) 6E3ACD5F-A70F-7AEF-AF2F-ADDA8A9D1189
Hardware information
Computer hardware
Hardware model: MacBookPro11,1
Processor: Intel Core i5-4278U CPU @ 2.60GHz
Memory: 8 GB
Architecture: Intel 64 bit
Video hardware
Graphics: Intel Iris 1536 MB
Memory: 1536 MB
Screen size: 2560 x 1440, 1920 x 1080
Displays: DELL U2515H (118dpi 1x), Cintiq 13HD (166dpi 1x)
USB devices
TOSHIBA: External USB 3.0
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple Inc.: Bluetooth USB Host Controller
Silicon Labs: CP2102 USB to UART Bridge Controller
Wacom Co.,Ltd.: Wacom Cintiq 13HD
Bluetooth devices
Apple: Apple Magic Mouse
Apple: Apple Wireless Keyboard
OpenGL information
OpenGL software
OpenGL version: 2.1 INTEL-10.8.77
Render version: 2.1
Shading language: 1.20
Maximum texture size: 16384 x 16384
Z-buffer depth: 24 bits
Maximum viewport size: 16384 x 16384
Implementation settings
Use texture compression: No
Appearance settings
Antialiasing: 4x
Mip map filtering: None
Anisotropic filtering: None
From the discussion from No export/import "tool palettes sets" possibility in the command editor:
I am not seeing that on my OSX 10.9.5. (not that I need it :smile:)
We did not disable the Duplicate option in any other version of OS X than El Capitan. It should still work in Mavericks and Yosemite.
??? @Dan: Uhm… I’ve never seen “import/export” options for custom commands in MacRhino (and I’ve been on bended-knee for this item for years!).
Maybe you mean “duplicate”? (which does work for me in 5.1 on 10.10.5 OSX) ~Dave
Yes. Freudian slip. I think I want Import/Export to work so much that I slipped up…correcting now.
I like the way you’re thinking, Dan! :smile:
is there a workaround?
Yes. Please see this thread.
