If a command has many options, its options are duplicated in the command prompt, as shown in the following screenshot. I noticed this bug in Rhino 7.1.
Not seeing that here -
(7.1.20337.5001, 02-Dec-20)
There is an update available, I will let it install and check again…
No, don’t see that in the current 7.2 RC either…
Hello - I believe what you are seeing is that if the command line is too short to accommodate all the options, a second set is overlaid that is not contained by the command line frame - here though, the overlay one obscures the actual command line so that I do not see it twice.
