Do you have a document with the translation of the different commands, specially for those you cannot find in the tool bar or a menu. For example what is the french command for “Sheel”?
Kind Regards
Alain
I found it. It is “Enveloppe”, but a translated list would be nice, when looking to a tuto in english.
The Mac Rhino Help file was recently completed and the localization translators are working on getting localized versions of the Help file finished. It should be relatively soon.
Sorry for the inconvenience.
Hello Alain,
If you already know a command in English, you can simply type it with an underscore first (for exemple: _Shell).
It will launch the command with it’s title in french (or any other language set in the preferences).
I hope it helps.
Nico
Many thanks to you both.
Alain
Also, here’s a list of the command equivalences FR-EN, http://wiki.mcneel.com/fr/rhino/commandlist
