How do I enable the Command line at the top of the screen? It is shown in a tutorial but I do not have it on my screen. Also, how do make an object using the diameter and not radius?
uncheck, check.
surf through the prompts of the particular command at the time, and find the toggle interface.
If you are using Rhino for Mac, there is no command line like this in the Mac version. The screenshot is from the Windows version of Rhino.
mac doesn’t sound very fun, maybe solution is get microsoft
Well, I have mostly used Rhino in a Mac so this hard to miss something that you didn’t have in the first place (the Windows style command line). You can type in the commands just as in the Windows version.
Ok. So how do i make an object using diameter and not radius?
What kind of object you are making? For example, if you are drawing circle there is a diameter option when the command is running:
Trying to make a cone and a box
The cone command has that same diameter option like the circle command. When you are drawing the cone and click the diameter-button and type in the diameter you want.
Here are the Help pages for the cone and box commands:
