I was wondering if there’s a command like shell to do the attached.
Thanks.
Not that I know of. Your best bet is to use BooleanDifference with 3 cubes as your subtraction geometry
-a
Thanks Andrew, that’s what I did… gutfeeling says there is a faster way
You could ammend @Helvetosaur’s script found here: Square pipe script
It’s almost there
That was done from curves though, not a solid.
Well, a plugin “nongenerictools.rhp” existed in 2007 on Mcneel’s site and works in Rhino 5 also. This plugin has 2 commands - flange and edgebox. The second one creates the shell, just input dimensions of the box and thickness of the walls.
I do not know If I can post this plugin because I don’t know if i need an angreement for it from Robert McNeel & Associates.
2 videos are available here
http://bbs.rhino3d.asia/thread-242-1-1.html
What I would do:
_DupFaceBorder 3 sides of the box (one in each axis)
_Offset the borders to the inside the desired thickness
_MakeHole 3 times with Direction=Normal and Through options
_Delete all unneeded curves
Done.
Don’t know if this is any faster than modeling 3 inside cubes and doing a BD, but maybe…
–Mitch
wow the movie totally shows what I am after! Would love to have the plug in!
