V5
what is best method to extract an interior box e.g. 40 x 30 x 12 made with cube tool from same which is .3cm larger all round ?
to leave a box with wall .3cm thick.
shell seems an obvious choice but its selecting one face.
Cheers
Steve
V5
Cheers
Steve
Offsetsrf
Hi @phcreates,
Unfortunately Offsetsrf just creates a new box inside the original. To create a void you have to follow it up with:
You now have a hollow box.
However, @Steve1, when you asked this question back in 2015 you went on to say that your 3d printer required a hole between inner and outer surfaces. If that is still the case then the alternative approach of creating the two boxes, then adding a solid cylinder that intersects both inner and outer surfaces and boolean differencing the cylinder and inner box from the outer box will serve better.
