Command: _Flow
Hi Rhino :grinning:
When I using the flow command, the target shape gets twisted. :confused:
FlowAlongCurve_Knead_1st.3dm (100.6 KB)
What’s wrong with this?
:coffee:…
Rotate your curves 90 degrees and the try the command again… Don’t ask me why, I have no idea why it works.
Also, I changed the degree to degree 4 and then used the command Fair to remove the kinks from your curve.
I hope that helps?
Andy
Huk! It works. :open_mouth:
This bug has been there for years. If a curve crosses one of the axis planes, it seems not so easy to handle that plane rotation on every point on the curve. Grasshopper as a fine solution to handle that ā€œtwisting planeā€ problem.
@pascal can we file that as a bug for V6 ?
c.
Hi Clement - I added Knead’s file, and a comment, to the bugtrack item. That item is not public yet due to the files attached…
thanks,
