How would I apply a gradient to these breps but instead of having each panel have its own color I want the gradient to be smooth.
Thanks in advance
Smooth Gradient.gh (7.1 KB)
Thanks in advance
Would it work for you to color the meshed surface (using same UV division) first, and then split at the end using the mesh face outlines? Is splitting even a goal? I guess you can also explode the mesh into faces (or extract the faces) and they should keep the color. Please clarify ![]()
Smooth Gradient.gh (12.5 KB)
Note:
I used a point for the distance values but you can substitute with your curve influence ![]()
Thanks that makes sense. What if i wanted to achieve this on a more complex surface that has a bunch of individual meshâs
Dont flatten the Vertex output of the âdeconstruct meshâ
âŠIÂŽd love to try GhGL here. to avoid meshingâŠ
I think UV is probably the best so it could be used in quite all render tool at the end.
Here is an example
The idea is to calculate the value '(1D) that is used for gradient and use it as texture coordinate (2D)
and to generate an image that represent the gradient.
This gh just need Nautilus plugin, a texture image will be put on temp folder. So if many tries many images generated
You can then transfert these UV to whatever object you want, with a limit distance
Then if you bake meshes in Rhino they have some UV map that could be used with a gradient put in a material
mesh with uv gradient.gh (25.9 KB)
You re-attached the old file, not the one with your latest more complex surface
Thank you all very much for the different approaches. My apologies for the re attachment
here is the correct file with the internalized meshes
individual faces.gh (5.8 MB)
I see your object is made of several disjoint meshes, I think by design?
Regardless, you just have to join the meshes (yellow component)
I made an attractor example (stuff in white group), just replace with your point:
Perfect. Exactly what I was looking for. I am new to meshes so I greatly appreciate the help. It usually is a simple solution I didnât realize mesh join worked if the geometry wasnât touching or intersecting.
Yes I guess âjoiningâ and âcombiningâ a mesh are sometimes used interchangeably - not really important for this operation - in other cases you might be looking for welding the mesh, which is definitely different from joining/combining.
If you feel the question is now answered please mark the response as âsolutionâ for others to find the answer easily.
