Color coded surface direction/orientation?
Someone posted a screenshot showing surface direction as a color coded display mode, instead of the purple arrows.
How do I activate this?
The standard purple arrows often become so cluttered with many objects selected that it becomes unusable.
Hello - use the Display panel to set colored back faces on surfaces - is that what you mean?
this:
and this to always shows naked edges:
There’s also this:
Thank you!
That worked great! Super convenient features that gets rid of a whole slew of diagnostics you otherwise often forget to check.
