Dir -> show arrows only on one side of the surfaces?
Currently the arrows of dir command visible on both sides of the surfaces, it makes it difficult to track.
Is there a setting or plugin that would hide arrows (or dim them) if they are on other side of the surface?
Thank you.
[EDIT]
My current work around this is to show backfaces as different color:
Color coded surface direction/orientation? - Rhino / Rhino for Windows - McNeel Forum, this way I don’t need to pay attention to arrows at all..
@vano_artful, can you attach this Rhino file, so we can test it? Thanks!
@vano_artful - I have added this as a wish list item. We will certainly take a look. It’s possible that we may be able to add a command line option to toggle the visibility of indicators that would be out of the camera’s view / behind the geometry.
RH-97365 is fixed in Rhino BETA
In the latest Rhino Beta, we now have a command line option to toggle the visibility of occluded arrows.
hm, I’m not seeing that in 9.0.26244.12303:
It’s in 9.0.26251.12303, 09/08/2026
Yes - got it now, thanks. I never realized that was something I wanted, but it is really nice (is something similar for Dots?)
IMO these arrows are still too cumbersome, why do we need them on the edges at all?
Personally, I prefer having backface in different color:
