Collide open curves in Kangaroo
Hello together,
I have a problem with my project with Grasshopper and Kangaroo respectively. The project is a kind of pavilion (picture 1). The top lines are built from wood and then of course do not intersect (picture 2). I tried to solve this problem with “Collider” and “CurveCollide”. However, both do not work, because I am dealing with open curves. Not even if I convert the curve to a polyline. Does anyone have an idea if there is a solution to the problem?
I think the better option here would be to get closest points between the curves in sequence and move by the partial results of their sum like this:
pipe_shift.gh (9.7 KB)
For collisions between pipes in Kangaroo you can convert them to polylines and use Collider on their segments, also keeping their shape with RigidPtSet. I don’t think that’s really what you’re after here though.
Hi Daniel, thanks for the quick answer. The problem is that the bottom line is fixed and only the arcs can move. These could stretch along the Z-axis. Is this possible or did I start wrong for this by stretching a semicircle.
