Clusters with a orange triangle and a black and gray diagonal stripes pattern
Hi all, I have some scripts I made on an other computer, and some scripts I worked on, but were done by someone else. Now when I try to use them on the new computer, I have some of the cluster components (almost all of them) with a orange triangle on top and a diagonal stripes pattern. They still work and if i click on random parts of them I can still open them.
My question is: what is this error? If someone can tell me the name, I can search some material on my own, the problem is I don’t even know the right keywords to search documentation about it.
Thanks in advance!
I have the same problem, was working fine, I shut down GH and opened it again and I have this now.
custler solutions are working, it is calculating the outputs.
cluster, not cutler
Right Click to the left of the triangle will give you all the options (internalize data, edit cluster, update, etc). Need to internalise the data. Edit: for another cluster I had to right click to the Right of the triangle so try both.
Same here, except I can’t even edit the cluster.
What’s up with these clusters ?
