hi
i just created a very small cluster of a few components. but I am not able to connect the output of the cluster to anything? Not sure if i did something wrong or if it’s just weird
I copied and replaced all three “last components” connecting to the outputs, and replaced the output tags. Then they started to connect again. Fast in-pathen funkade inte så bra, men det var en annan historia.
I didn’t dive v ery deep into the problem. Could it be that the Swedish characters played a role in the problem? I just scrapped them - to no avail - and then replaced the items altogether.
bumping this as I’ve been running into the same issue receantly. It seems the issue is connected to outputting data defined in the cluster (not manipulating data). In my case I have a string that’s set in a panel component in the cluster, and where the output can’t be connected to anything.
I faced your case. I add a “text component” before the “cluster output component”, that would fix. I think maybe there is something with the data type when you connect with a panel, cluster does not recognized it.
