CloseCrv stopped working
in the latest update of Rhino 8, CloseCrv does not work anymore.
/Erik
Hi @erik6
Initial test show, that it works fine here. Post curve that isn’t working and SysInfo.
-Jakob
closecrv_notworking.3dm (42.6 KB)
This supersimple crv does not close here.
Brand new 3dm file.
/Erik
It works fine with your 3dm file on my side, and fyi.
closecrv bug
But it does not close here.
Rhino 8 SR29 2026-3-4 (Rhino 8, 8.29.26063.11001, Git hash:master @ bbd126f84fcdaf7a974615b7c9f4f8667571c147)
License type: Commercial, build 2026-03-04
License details: Cloud Zoo
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 96GB)
.NET 8.0.14
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 4090 (NVidia) Memory: 24GB, Driver date: 12-30-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 591.74
Accelerated graphics device with 4 adapter port(s)
  • Secondary monitor attached to adapter port #0
  • Windows Main Display attached to adapter port #1
Secondary graphics devices.
Intel(R) UHD Graphics 770 (Intel) Memory: 2GB, Driver date: 12-1-2025 (M-D-Y).
Integrated graphics device with 4 adapter port(s)
  • There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-30-2025
Driver Version: 32.0.15.9174
Z-Buffer depth: 24 bits
Total Video Memory: 24564 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.29.26063.11001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.29.26063.11001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.29.26063.11001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.29.26063.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.29.26063.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.29.26063.11001
C:\Program Files\Rhino 8\Plug-ins\Calc.rhp “Calc”
To close this curve, the CloseWideGapsWithLine option must be set to Yes. To get to this setting, run _CloseCrv with no open curves preselected.
Hm,
ok, but then this setting has changed from previous versions? Because I’ve closed all gaps since I’ve started using Rhino … without changing any setting …
/Erik
Regardless of CloseWideGapsWithLine’s default setting, once it’s changed and the command completes (not canceled), the setting appears to be retained between Rhino sessions. The same is true for the Tolerance setting.
Weird.
Anyway. Now it works. So this was not an issue, but a setting that somehow changed.
Thanks
/Erik
