CloseCrv Not Working
I’m using Rhino 6 and for some reason my CloseCrv command hasn’t been working for a while. I’ve had this issue for all my files and all the lines are planar. I’ve tried updating the software but it doesn’t seem to help. Can anyone help me?
Hello - does the command run at all? Does it work on some curves but not others? If that is the case, please post an example curve doe which it fails.
It says “1 curve not closed” every time I run the command.
closecrvfailEx.3dm (42.8 KB)
Hello - thanks for the file - these curves all close, here
Please run the SystemInfo command in Rhino and copy/paste the results here.
Rhino 6 SR34 2021-2-3 (Rhino 6, 6.34.21034.07001, Git hash:master @ 2fec8130f097ca52a8bc9f334c3ed4a5921c5e30)
License type: Educational, build 2021-02-03
License details: Cloud Zoo. In use by: - ()
Windows 10.0.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: -
Computer platform: LAPTOP - Plugged in [82% battery remaining]
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 9-25-2019 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 2070 with Max-Q Design (NVidia) Memory: 8GB, Driver date: 12-28-2018 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 417.59
> Integrated acclerated graphics device with 4 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-28-2018
Driver Version: 25.21.14.1759
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.34.21034.7001
C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.34.21034.7001
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.34.21034.7001
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.34.21034.7001
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros 6\VRayForRhino.rhp “V-Ray for Rhino”
Hello - please make sure that ‘CloseWideGapsWithLine’=Yes.
Sorry where do I make sure that command is yes?
Hi -
Make sure that no objects are selected when you run the CloseCrv command.
You will then be asked to select a curve but will also have 2 options on the command line: CloseWideGapsWithLine and Tolerance.
