Version 6 SR23
(6.23.20055.13111, 2/24/2020)
Commercial
Same build on teammate’s Rhino works fine as expected.
I’ve restarted my workstation, same results.
Is there some secret hidden switch for this command that I’ve tripped somehow?
Can you upload a .3dm file with sample curves that will not close? You can either drag the file to where you type your post, or use the vertical arrow icon above where you type.
Wow. some how that option got ticked to no. I haven’t used the pre-invoked version of this command in so long I’d completely forgotten about this option.
Thank you!
