Close mesh to get continuous inflation in kangaroo
im new to Grasshopper but I’m now trying for days to get a closed mesh as a ring and inflate it without getting peaks on the edges the mesh meets itself (end/beginning).
i tried this with weld and join and weaverbird (mesh from lines) but in weaverbird the outgiven vertices are unusefull sorted in x-direction what is hard to handle with in upcoming worksteps.
could someone please help me to get a continous/closed mesh ? or to sort the vertices in Weaverbird by isocurves?
weaverbird-mesh_sort vertices.gh (10.9 KB)
unclosed mesh.gh (11.7 KB)
According to your description, your anchor points setting doesn’t make any sense.
See red groups.
unclosed mesh_re.gh (18.0 KB)
As @HS_Kim mentioned, there is no problem with your mesh. If you want to split the list of naked vertices you can use Dispatch like this:
Jonaremer.gh (25.5 KB)
Thanks for your help, i thought it could be easy like this. just didnt get the point.
Thanks.
