Hi! Im trying to make a closed mesh (sphere style) with the points I created, but for some reason I am not getting to the result. Anybody knows what can be missing? I am not a frequent user of Grasshopper, I would be very grateful if somebody can help me out!
Awesome as always Laurent - I was about to say it seemed the alpha shape method, or the point volume method, still left a point here and there unaccounted for. Thanks. How would you close this mesh? Fragment patch on the naked opening?
I will have a look but I still donât use R8 by default as I didnât purchase it.
I also try to install ghshadernode without success. Normalize doesnât appear.
Normalize just duplicate data ! So I change it with simple components.; I closed the mesh with Pufferfish component FrecuenciaCardiaca5_RH8.gh (19.9 KB)
Hi Laurent, I tried closing the mesh creating the polar points and using delunay (like you told me), but havent managed to close it. Is there any other way to do it?
There are many ways
Or you extract the points from your list
Or you extract Naked Edges and you join them then use points.
I also added a middle point.
Delaunay must work if you provide a plane
