how can i close this curves.
close curves.gh (12.3 KB)
You could do something like this:
close curves_V2.gh (18.6 KB)
Pufferfish also has a simple Close Curve component.
Its because the lower 3 curves aren’t fully joined. If you use Join Curves first, then Close Curve should work.
my initial problem was, not remove the empty branches so clean tree, join and close curve, that’s it … thanks again
@Adam_M doubt ,closing in this way I can’t get individual panels I want individual panels How do you would do it?
They already are individual. Not sure I follow. Do you want all bricks to be joined?
you are right I had flatten in join curves but all is ok thanks
