Closing open curves
i have this definition and i want the open curves connect each other so it gives me a nice closed boundary. there are lots of these shapes with small variation in different Z, so i want a parametric way to close the curves.
Fabrication.gh (20.5 KB)
There is a blend curves component.
it wont work for this situation. Blend Curves cant actually identify the gaps.
the close curve component in pufferfish plugin didn’t help either.
Close curve closes an open curve (like rhino closecrv) , this is not one open curve. What I meant was connect curves which is essentially a sequential blend curve.
Fabrication Connect.gh (29.7 KB)
Wow! Thanks. What a beautiful way of solving this problem. Thanks Michael. It solved the situation perfectly.
This one helped me right away. Thank you so much! :))
