ClippingSections problems
When I have a clipping plane active on top view some bugs appear:
  • the lines doesn’t appear while I draw a polyline, the complete polyline only appears once the commande is done.
    Also, intersections snap doesn’t work.
When I disable the clipping plane averything goes back to normal.
Can these issues be fixed to avoid any drawing problems while having clipping planes ON ?
Thank you,
Best regards,
Arthur
@Leitner_Arthur I don’t see that issue over here. pls run _SystemInfo and post back the results as well as an example file that illustrates the problem.
First image is whil drawing a polyline on the “invisible side” of the clipping plane: only points appear:
second image is once polyline commande over, the polyline appeared in the “invisible side” of the clipping plane, and whil edrawing a polyline on the “visible side” of the clipping plane, polyline commande behaves well: the lines appear while drawing the clipping plane:
third image is the intersection snap not working on the “invisible side” of the clipping plane:
Fourth image is Points On command made on both polylines:
Polylines can be edited in both visible and invisible sides, but points only appears in the “visible” side of the clipping plan:
Here is the file:
clipping plane issue - Arthur.3dm (127.7 KB)
Thank you,
Arthur
Ah, clipping sections. Thanks for sending the file.
I can reproduce what you are reporting. I’ll check if these are known issues and otherwise log them.
RH-83783 ClippingSection obscures polyline
RH-83784 Polyline features get obscured by clippingplane
RH-83783 is fixed in Rhino 8 Service Release 13
