Hi, creating different views using clipping plane for my layout pages, the edges where the clipping plane is are very very thick, they don’t look like this on the layout page, only when saved out to PDF (vector)
Hi - in a simple test here, I cannot reproduce this. Is this file-specific on your side? If not, please provide very specific instructions on how to reproduce this.
Thanks,
wim
Hi Wim, simply using the clipping plane, then make2d for elevation views to use on layout pages, it doesn’t look like this on the layout page (screenshot attached). Its only after printing out to PDF when the issue crops up. I have tried the RhinoPDF and Bullzip PDF as output, same issue
Ah - as such, the clipping plane doesn’t really have anything to do with this. It’s just Make2D
that, by default, sets the print width of clipping lines to 0.5
, whereas other lines produced by the command have the width set to Default
You can easily change the print width of individual curves or layers.
HTH,
wim
ah yes, why didn’t I think to check the print thickness , thanks Wim, appreciated
